‎2021-09-13 01:37 PM
How do you deal with tolerance when creating custom doors?
The get no setting for the tolerance...
Br,
Mats
‎2021-09-13 02:42 PM
Doesn't the Custom Door just scale to the specified leaf size and all other tolerances are part of the frame GDL settings? Or do you mean something else?
‎2021-09-13 04:15 PM
I know a custom door leaf will scale to fit the door frame you use it in - no matter what size you model it.
If the frame object does not have an option for tolerances, then maybe you could model an extra air space slab (invisible/transparent material) with no perimeter lines around your door slab before you save it as a custom door.
Effectively you are modelling the tolerance.
I haven't tried it but it might work.
It won't be adjustable but should create a small gap if it does work.
‎2021-09-14 12:03 PM
I can model pretty much what I want but since it's BIM I need to schedule the tolerances (as well as unitsize and wallhole size).
