2023-09-21 04:54 PM - last edited on 2023-09-25 04:05 PM by Laszlo Nagy
Hello
In this file, there are many solid elements operations concerning the site terrain and some between walls and false ceilings, but not on the walls the doors belong to. The file size is 650 MB.
Any explanation for this? SEO is not the case here (the walls would be cut too). I've also cleared all connections.
Solved! Go to Solution.
2023-09-21 11:30 PM
It is possible to CROP to a single plane roof. The effect is permanent and unlike SEO the roof doesn't need to be present. Not sure why you have so many different cuts, but select your cropped doors etc and then right-click for the context menu and select "Undo all crops".
2023-09-21 08:43 PM
Maybe try this: select all doors in the 3d view and delete them. Then just do undo, normally it will redraw everything correctly.
2023-09-21 08:46 PM
Thnx. No, it doesn't work. I've tried that.
2023-09-21 11:30 PM
2023-09-22 01:15 AM - edited 2024-09-02 12:17 PM
Thank you. That did it!
