Doors disappeared in plan view...Need Help...
I am working on a 3 story building and it seems, that at some point, something went wrong and all doors on story 0 disappeared...
But only on the plan view...they appear just fine in the 3d window/sections/elevations...
I can't tell when and how this happened...I can't make them appear again on plan, no matter what i tried...Also I tried to create new doors/win on that same plan with no success...They don't appear as well...On the 2 other stories doors/win appear as they should....
To solve this, i tried different model view options, I enabled all layers, checked all the renovation status options and nothing worked...
I can't think of any other possible solution.... Any help, would be much appreciated...
Thanks in advance!
PS: I'm using ArchiCAD 19 Build 4011 on Win8.1
3 REPLIES 3
David Maudlin
mpoulis:
Another thing to check for Walls and Doors: Settings > Floor Plan and Section > Floor Plan Display > Floor Plan Display > Symbolic Cut (which ignores the Floor Plan Cut Plane). Or check the settings for the Floor Plan Cut Plane.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David wrote:
mpoulis:
David
Hi David,
Thanks for your reply!
Checked those but neither solves the issue...
Floor Plan Cut Plane is the default and Floor Plan Display for Doors/Win is set to Symbolic as by default, which works on the other stories...Changed it to the other option but didn't have any results...
Could it be a bug or something?
Solved it!
Although it seems to me there might be a bug...
The floor plan display of the walls, was set to projected as by default, and for the doors was set to symbolic...
So I changed the walls display from projected to symbolic cut, and the doors reappeared...Good...then i set the display of the walls back to projected and the doors still appear....So I have my doors back for good, but....what happened and made them disappear????
Anyway Thanks David for your help!
