ngoldie
Doors have disappeared Archicad 23
My doors disappeared, all of them. I still have my windows.
They aren't visible in the 3D view either. I think it may have happened after I changed the storey level. I changed it back to level 0 however they are still gone??
I use Macbook Pro.
Any help is appreciated!
Thanks
Naomi
Archicad 20
MacBook Pro - laptop
3 Replies 3
Are they set to a renovation status that is currently set to hidden?
Try setting a different renovation filter to see if they come back.
Djordje
Check also MVO, scale, library, partial structure display...
And what did you EXACTLY do with the storeys?
If you are sure that something is there, but you cannot see it, open the 3D window, show all, all layers on, Renovation filter Show all, zoom to fit, activate the tool (door for doors, in your case), and hit CTRL A. If the outlines of the doors appear somewhere in space, move them back where they should be...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
ngoldie
Thanks for all your responses.
It turns out, I may have accidentally selected them all and deleted them. I tried the above but they didn't appear anywhere..
I had changed ground level,  storey settings.
Thanks again
Naomi
Archicad 20
