Doors in 2d
This is probably an easy question (I hope)-
All of a sudden the pocket doors in my plan appear to have a solid fill in the door itself and in the wall cavity. I have looked in Door selection settings under 2D representation (parameters) and Floor plan, but I cannot seem to get rid of this solid fill. Can someone help me out?
3 REPLIES 3
Thomas Holm
Did you change pen set?
I did not change a pen set, but I have done work on the same file on two computers, I notice that this leads to difficulties with library management, as the paths to the libraries are different. I believe the problem arises from this. The library manager will often leave out just one part of a library (doors for example) and I will go through an exercise to load the doors again. It was in doing this that the characteristics of the door changed, which wouldn't be so bad if I could just change them back.
Thomas Holm
I would guess that it's the fill background color that's causing this. Check the door“s parameters to get the pen (color) number. Either change that to something transparent or white, or create a new named pen set where that pen number is white.
