2011-10-24
06:45 PM
2023-05-24
01:02 PM
Rubia Torres
2011-10-25 08:50 AM
2011-10-25 01:34 PM
2011-10-26 12:08 PM
2011-10-26 12:10 PM
2011-10-27 01:26 AM
2011-10-27 03:58 PM
ahmed_hassan wrote:When you are in the 3D Window as per your screen shot, you should be able to select just one of the vertical Scheme lines then delete it, combining the two adjacent panels into one for the double door, but the panels above will also be combined.
to hillsee as i understand your point of view but this did not lead me to the solution
2011-10-28 11:18 PM
2011-10-29 07:19 PM
2011-10-30 03:06 PM
ahmed_hassan wrote:Not sure why, it works here. In 3D Window select Curtain Wall, click on edit button, turn on Scheme, turn off Frame and Panel, move cursor over vertical scheme line to be removed, click on it, hit Delete button.
David thanks for reply , but i am not able to choose one of them , when i select it select them all. which will not enable me to delete any mullion.
