Double flight staircase
EdwardBotes
Fairly inexperienced AC user.
Would like to know if the stair tool can have two flights as the first half run of the staircase merging with one flight for the second half.
I've drawn a little sample in plan of what I'm trying to achieve.
Thanks in advance
Emre Senoglu
Unfortunately not. Best you can do is this:
AC27 ARM // MBP M2 Max // Twinmotion | Corona | Rhino
senoglu.co | archimats.com
Emre Senoglu
Hi Emre,
Thank you for the prompt response and feedback. Much appreciated.
Regards,
EB
