Downspout problem in AC14
In arhicad 14 version.
In picture "Capture 1" it's showing ok in 2d, 3d. In this picture it was started a new file in ac14, with all the defaults values.
In picture "Capture 2" in 2d it's not showing the hole body of the downspout, in 3d it's ok. Here the file it's an old file, with values from ac12, and open in ac14. Also here i have loaded the ac9 library, but i have did the same thing to the new file where the caputre 1 it's ok, and it's not haveing a connection with the ac9 library loaded.
I know sure that it's a modified value, because in a new file with default values it's working and I do not know where to look and what to try to see it right.
the file capture 2
i want to say that i have look in the properties of the downspout, but i didn't find anything strange.
nobody knows? or you do not understand what is in the pictures!?
i get it. i upload a picture.
