How can i change view range
How can i change cut plan setting for Specific level and view range of it . not for all level.
5 Replies 5
In the Document\Floor Plan Cut Plane Settings Dialog?
first, thanks for reply Mr .laszlonagy .... but i am talking about Set Separate Floor Plan Cut Planes in Different Views. when i search in "help of archicad"
i found this : For every view, you can define a unique Floor Plan Cut Plane, if required, using the Floor Plan Cut Plane controls accessible from View Settings. but i didn't found view settings in tools bar or in any place in archicad to change view range in Specific level without other levels .
See screenshot for View settings...
Thanks very much Mr. Karl Ottenstein .This screenshot solve my problem .
Djordje
In general:
Every View is a drawing to be placed on the layout - or your documentation sheet.
All the View settings define what is that drawing going to look like.
As usual, Karl has provided a perfect illustration ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
