Dragging and Rotating
:shock: when dragging or rotating, I do not get the vector to assist me in moving it to the new location. Is there a setting that I can change? HELP! :shock: :shock:
4 Replies 4
Having troubles...when I attempt to drag or rotate, I do not get the vector (tail) that allows you see in real time where your are dragging the object to. Is there a seeting that I can change to activate this feature. Troubled in LA.
Thank you in advance!
I don't think that there is an option to control this feature.
Probably it is hardcodded and impossible to change it.
Try to open a previous file and test again or reinstall AC
Djordje
Sounds like a video card problem; do the video card test, available at the main page of the Talk, in the bottom.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
David Collins
Check to see if you have OpenGL enabled for 2d redraw and if so, try switching it off. ( Options/Work Environment/2d Redraw Options/Optimize drawing method.... )
David Collins
Win11 64bit Intel i9 3.40 Ghz, 64 Gb RAM, GeForce RTX 5080
AC 29.0 (3100 INT FULL)
