Drawing a handrail
I am trying to draw a handrail with only innerpost and without balusters and panels. I am setting the innerpost every 100mm and in the preview in the window of the handrail tools I can see it every 100mm, but when drawing in the play they only appear every 80cm, never like the set up position in the window settings tool.
1 Reply 1
Are you using the fixed length for the rail segments?
You can choose if you want the pattern to start from either end or the centre.
