We value your input!
Drawing an Arc Length
Is there any way to draw a precise Arc length using Archicad?
I am working from a surveyor's drawing, and need to input the arc length with a given radius.
(I think I know the answer is "no" or "buy an add-on" but I am posing the question so I can ask the next question: Why not? )
26 REPLIES 26
Stephen Dolbee
Any arc I have drawn (from a survey) has been in tangent with a line or another arc. I just go 90 degrees from the endpoint to find the center of the radius.
Steve
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
Jacek
"Seiss Wagner" wrote:
I have tried various strategies with the three point circle tool, with no success.[/quote
and Steve wrote: "I just go 90 degrees from the endpoint to find the center of the radius. "
-That's the way I do it
jacek lisiewicz
arkhos-tekton, architects
carmichael, ca
Mac OS X 10.15.5
IMac Retina 5K, Intel Core I7
32 GIG Memory, AMD Radeon R9
ArchiCAD 24
Seiss Wagner
Steve or Jacek
I don't follow how you go 90 degrees from the end point to find the center of the radius. Can you give my dim mind a screen shot of what you are doing to get a surveoir's arc.
Seiss
ArchiCad 21 / OS X 10.13.5 /
iMac 3.2GHz i5 - 32GB /AMD Radeon R9 M390 - 2048 MB/
Dual 5K - 27" Displays
Stephen Dolbee
Seiss wrote:
Steve or Jacek
This example might be a little simplistic, but here it is. Hope it helps.
Steve
Seiss Wagner
Steve -
Thanks much for the screen shot, it really helped. Which Arc/Circle tool are you using? If I use the Three Point Tool I can draw the cord, constrain 90 degrees with the perpendicular icon, but then I must pull the diameter of the arc to get the radius. Is that how you do it?
Seiss
Erika Epstein
Another method is to draw a circle of the known radius at each end of the chord. Where the two circles intersect is the center of the arc you are looking for.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Stephen Dolbee
Seiss,
I use the center point circle.
Steve
Seiss Wagner
After further investigation, I have found the three point circle tool does not work for a chord arc as I had previously posted. It only seems to work if the radius is large. The three point circle tool will work for a chord arc if you bisect the chord and and graphiclly input the chord rise which equals r-½ the square root of (4r²-c²). But this is more effort then either Stephen's or Erika's posts.
So I guess it is back to drawing circles. ':('
fuzzytnth3
Seiss wrote:
Finding the length of an arc (circumference) is of interest, but of limited value. A much more interesting and useful question is how do you draw an arc knowning the cord length and radius without resorting to geometry?
I made a library object that does this. I've attached it below. We found it very useful when setting out a multiple curved building.
Enjoy
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
The character in Scotland made a goodie!
This deserves praise for cleverness, though curses to Archicad for needing it.
Put this one on the Tips and tricks board!
