Drawing arc lengths
I am constructing a site plan and have the radius length and the arch length. How would I draw a specific arc length?
Thanks in advance
Happy Hoildays
10 REPLIES 10
One way to do it, once you have drawn the arc (oversized) you can use the distance tool (with divisions etc) and stretch your arc back to the correct length. Note that it measures from the closest end where you first hover over the arc.
TomWaltz
I never thought about that before..... Yuck!!
Tom Waltz
How would you do it?
Aussie John
Good thinking Stuart
Messy way to do it but I am not sure this is an easier way.
Cheers John
[/size]
Erika Epstein
What about geometry?
If the circumference of a circle is 2πr
arc a =arc length
then to get the angle θ defined by the radius and arc length both of which you know:
θ = (arc a)360°/ 2πr
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
TomWaltz
I meant that I never thought about drawing by arc length. It doesn't seem like there's a good way.
Tom Waltz
Aussie John
If the circumference of a circle is 2?r
arc a =arc length
then to get the angle ? defined by the radius and arc length both of which you know:
? = (arc a)360°/ 2?r
Actually Stuarts way is very easy. I like the CAD method as I dont need to calculate things like you had to in the pen and ink days. They aint called computers for nothing
Cheers John
[/size]
Erika Epstein
Not a problem; I prefer a more precise method.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Don't you all design with a Calculation at your side?....
I guess this is only for the Engineers. Erika, (as most times) is correct and brings us the most efficient way.
Delta = ( 180 * Arc length ) / (Pi * Radius)
This delta is the distance "a" to "drag" the arc. I usually just start the arc and leave the cursor at the beginning and then type"a", then type the angle (i.e. 45d23'15") and then the + (or negative depending on the direction), then enter.
