ELEVATION DISSAPEARED
I can't figure this out.
The elevation marker shows in 2d, but when I open the elevation window all I get is a blank screen. However, Plotmaker will update the elevation correctly and I can see and print the elevation.
I have "rebuilt the elevation from model", zoomed out/in, eyedroppered from another elevation marker, restarted, punched my desk.....nothing works. I always get a blank white screen, with the black "x" origin.
All my other elevation in this project and other projects work fine.
Help!
1 Reply 1
Aussie John
Maybe you have a object or element accidently located some distance from the remainder of the elevation. So far away that your elevation is too small to see. If you had cropped the elevation in PM then the distant object will not show. Select the fit to size check box in plotmaker and you will soon tell if there is a distant object
Cheers John
[/size]
