EXPLODED PDF'S WON'T PUBLISH publisher won't accept drawings
I was sent 10 sheets to convert into dwg files, then export back. I have exploded all, placed each title block on a sheet, then placed the drawing on the sheet (sort of reproducing each sheet as it came in). Now wanted to put all into a publisher set and email.
Publisher seems to be not working (AC18) in that I can't put anything in the colum on the organizer...Usually drag the sheets from the sheets to the organizer but that won't work...ANYBODY KNOW WHY?
SOLVED THE PROBLEM!...when importing a pdf to explode, one must START in AC 18, 19, whatever version one is using, then import the files to explode. That way the entire layer/layerset/program loads. My mistake was opening the file as a dwg into AC18 which didn't give me all the necessary tools, but only loaded the (e) layers from the file I was opening not AC18 file....So, I loaded the AC18MT, deleted the layers, layer sets I don't need, and Voila! it works....was able to export .dwg and PDF files. PROBLEM SOLVED!
0 Replies 0
