EXTENDED AUTOMATIC DIMENSIONING
BY SETTING A 0.00 mm dimension (in a future hidden layer) WALL AND WITH MAGIC WAND YOU CAN "TOUCH" SLABS, LINES , ROOFS , ( EVEN ELEVATION LINES PASTED IN FLOOR PLAN) AND PUSH THE AUTOMATIC DIMENSIONING TOOL.
AFTER YOU CAN HIDE THIS HIDDEN DIMENSIONING WALL LAYER.
DIMENSIONS REMAIN
3 Replies 3
David Larrew
You might want to submit this to the "Tips" section and refer back to the original thread.
David Larrew, AIA, GDLA, GSRC
Architectural Technology Specialist
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
David Pacifico
I'm not following your tip. Could you explain it more?
Maybe a step by step approach.
Thanks
David Pacifico, RA
AC27 iMac i9, 32 gig Ram, 8 gig video Ram
ESCUSE MY POOR ENGLISH
BECAUSE ARCHICAD ADDON NAMED AUTOMATIC DIMENSIONING WORK ONLY WITH WALLS I FOUND A TRICK TO EXTEND THIS TOOL PRODUCTIVITY.
I CREATE A LAYER NAMED " DIMENSIONING GHOST WALLS" AND OF COURSE I SET THE WALL TOOL TO
O.OOmm TO ALL DIMENSIONS TO OBTAIN THE ZERO DIMENSION =GHOST WALLS
WITH WALL TOOL ACTIVATED AND SPACEBAR (MAGIC WAND) I CLICK OVER OTHER ELEMENTS (LINES,ROOFS,
SLABS...) OVERLAPING INVISIBLE WALLS .
AFTER THAT I USE AUTOMATIC DIMENSIONING AND I HIDE" DIMENSIONING GHOST WALLS" LAYER
FOR EXAMPLE I USE THIS METHOD FOR QUICK DIMENSIONIG ROOFS CONTOUR
I POSTED THIS MESSAGE HERE BECAUSE THE TRIPS FORUM IS LOCKED
