2006-11-01 02:14 PM - last edited on 2024-07-09 11:49 AM by Aruzhan Ilaikova
2006-11-01 10:27 PM
2006-11-02 12:17 AM
mykey38 wrote:presumably you know at what height you want to se the skirting, chair and/or crown moldings up and down your wall? simply set the values you need in the moldings and panels dialogue . . . archicad doesn't design it for you!
Hello all.. I am new to archicad and wanted to know if there is an easy was to connect floor molds and crown molds to walls.Right now i add the floor mold and but it usually is below my slab so i manually move it up until it looks like it is connected to the floor and wall.
Also, is there an easy way to add objects on top of another object. Say a lamp on a table? Right now i sort of "eyeball" it until it looks like it sits on it.as john said: never ever eyeball! use the height values of selected elements from your info box to determine the heights of new elements.
2006-11-05 05:51 PM
2006-11-07 02:35 PM
2006-11-07 02:47 PM
2006-11-07 08:29 PM
2006-11-07 08:37 PM
