Easy way to make facia
After searching for past posts on ways to make facia I did not find much. I haven't played with archiforma much but I have found a very easy way (for me that is), using the roof tool. I can set the facia thickness and height, miter the inside and outside corners, set the facia square or plumb, level or raked, and the plumb cuts fit perfect too. I think its very clean and easy. Tell me if I'm trying to reinvent the wheel. I know that I'm limited to just a square profile this way, but it seems its a simple way to make facia within ac. Attached are a few boxes the I experimented on for all of the typical applications.
Thanks, Jim
1 REPLY 1
TDabney
Your method does work really well for single tier facias but. . . what about 2-3 tiers? It is possible, but gets complicated pretty fast.
TND Architects P.L.L.C.
macOS 12.7
2021 16" MacBook Pro
Apple M1 Max
ArchiCAD 26/27
