Edge line between column and slab
Hello fellows archicad users,
I am new in this forum and also starting a new with archicad.
At the moment I am training but I already need to work on a real project.
Here's my question:
I have columns supporting a concrete slab.
I would like to a see a horizontal line between column and slab.
In my case it doesn't show any line. How could I solve this problem?
thanks for any suggestion
MiD
alemanda
Use a surface for column different from that one of the slab
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
MiD,
Welcome to the forum and Archicad.
Firstly, please try to post in a relevant section of the forum and not just the 'Archicad+' section.
The section descriptions will hopefully help you choose the correct one.
By way of further explanation, if adjoining elements have the same surface material and their surfaces are in the same plane, then they will join seamlessly - no joining line - as they probably would appear in real life.
You will need to two different surface materials to see a join.
If you really need the same surface and still have a line, then you can duplicate the surface (in the surface settings dialogue) and give the second one a slightly different name.
Then use those surfaces.
