Edge visibility of wall in plan
ratnabhirud
Hello,
Why edge of the same wall is showing different in plan. (AC ver. 14)
Attaching snap shot .
Regards,
Ratna
AMD Ryzen 5 3600 6-Core Processor 3.59 GHz
Ram - 16.0 GB
System - Windows 10 Ultimate, 64 bit
NVEDIA GForce 8400GS
Archicad 9..., 24
10 REPLIES 10
ratnabhirud wrote:
Hello Riiiiv,
You found the problem correctly,
Thank you very much.
Regards,
Ratna
Hi ratna,
I had to beware of "micromet deviation" (see attached image). many times they cause unexpected or missing lines at wall connections
It remind me that I had to have 1-day-stomachache to check why there's redundant line at wall connection in a UK masonry house with many types of composite walls as I thought I did everything right! Checked wall priorities, checked Floor Plan Display,...when nearly give up I thought suddenly: "did I draw NOT EXACTLY RIGHT?", zoom in and I found the problem luckily !
Now I usually re-draw elements that cause problem when tired of looking for solutions ! many times it helped!
Regards,
