Thanks Dwight, I understand about the story floor setting.
I made āāthe design for the 19 storey building.
Ground Floor Height 7 meters, level 2 = 4.5 meters. Floors 3-19 = 4.5 meters
Say all the objects on the upper floors have been made complete, and I want to change the height of the raised ground floor plus 125 centimeter height of 7 meters to 7.125 meters high and I subtract a Level 2 = 4.375 meters. High floor 3 to floor 19 onwards remains unchanged.
By changing the ride height of the ground floor of 125 cm on floor setting this story would raise practical as well as all things that exist on the floor 2, 3 and so on will go up 125 centimeters change.
How can I make all things interior second floor did not go up above 125 centimeters by changing the floor height changes that occur in the ground floor and second floor.
I raise the height of the ground floor, all the objects on the floor 2, 3-19 will go up simultaneously.
Maybe I should go back to manually raise and lower it back?
I know that this will automatically apply when added up nor when it will be reduced then it will go down.
There are some objects that are exceptions and I want this object does not change altitude level.
