SOLVED!
Editing Plane
Zdenko
trying to figure out what i did to create an editing plane that is way off of where my workspace. looked for any entities but have not found any. any suggestions...
Archicad 27 5030 USA Full Apple
M3 Max 36GB MacBook Pro
Sequoia 15.1.1
1 ACCEPTED SOLUTION
Solution
mthd
Try selecting all elements with CMD a, on Mac or CTRL a, on windows from your 3D screen. Then see what happens, you may have to zoom out as well if something is actually selected.
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
12 REPLIES 12
Solution
mthd
Zdenko
did not think of that thank you!
Sequoia 15.1.1
No worries, accidentally placing an element out in space can easily happen to any of us.
hello again - it seems that today the issue occurred again. this time i could not find any elements and for some odd reason when i try to rotate in 3d the zoom level is way out of whack? any suggestions to look into within the settings. you can see in my perspective 3d view settings that the coordinates are out in space, but can't figure out how to get them back in check.
Sequoia 15.1.1
Hi @Zdenko,
You can read this page regarding (View Cone), I hope it helps you.
AC 28 INT 5200/WIN 11
Hi @Zdenko, that’s strange. Do you have a scroll wheel on your mouse ? If so, when you roll it forwards it should zoom in and if you roll it backwards it should zoom out. Do you get the same result with the other 3D view (Not Perspective) ?
We are asked to make a separate thread for each new issue so please start a new one so someone can help you out further.
Thank you.
Perspective views are great for presentation, that is what it will look like in real life.
But the extent of the model will affect how it rotates and zooms.
I find working in Axonometric mode is so much easier.
i will mess with the "view cone" and see how it impacts my scrolling/zooming with mouse.
Sequoia 15.1.1
i have a logitech mouse with wheel (personal preference) and when i roll forward or backward it correctly zooms in and out, however the rate of zoom is exponential and not controllable to view in 3d. i will look into starting a new thread after messing with the recent recommendations...
Sequoia 15.1.1
