Elements on off layers are cutting walls. Why?
Does anyone know why walls can be distorted by walls/columns on a different layer that is turned off? How can you stop this problem?
This is apparently a "feature". You can stop it happening by assigning different intersection priorities in the layers settings dialogue. i.e. same number will effect each other, different numbers will not.
Be sure to update the layer combinations when you have altered the setting.
Hope this is clear.
Ok I got it. Thanks for the help.
Also, please note that the layers can have different number priorities in each layer combination. They need to be set in each.
