Elevation markers size
Tom Krowka
Can't get the elevation marker to change size. I can change the size of the text, but not the round marker itself. (in the section/elevation dialogue box)
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
8 REPLIES 8
Which marker are you using for your elevations. I am using the Marker_NSC SE9. I think the settings are the same for this marker for the last three libraries.
If you open the marker's settings (control-T) you will see one called marker. There is a setting there to adjust the markers size. The one above is for text size.
I am not sure how every marker works but they are all probably similar.
Try changing the highlighted field...
Tom Krowka
Changed the field in the dialogue box. It has no effect on the marker size on the plan.
Thomas@wkarchwk.com
www.walshkrowka.com
Does is change in the preview window within the sect/elev dialog box? What marker are you using?
Which Marker are you using?
Tom Krowka
Am using elevation marker SE9. Have had this problem with other markers too.
It does not change in the preview field.
Thomas@wkarchwk.com
www.walshkrowka.com
That marker seems to be buggy in that regard. It seems like that marker is intended for interior elevations - is that what you are using it for? Try the Elevation Marker_NCS SE9 if you are using it for exterior elevations. If you are looking for an Interior Elevation Marker Tom Waltz posted one he had made at this link (thanks again Tom).
http://archicad-talk.graphisoft.com/viewtopic.php?t=6319&highlight=interior+elevation+markers
Tom Krowka
Am using it for interior elevations. Thanks for the tip about the Tom marker. Will check it out.
thanks again.
Thomas@wkarchwk.com
www.walshkrowka.com
