Which marker are you using for your elevations. I am using the Marker_NSC SE9. I think the settings are the same for this marker for the last three libraries.
If you open the marker's settings (control-T) you will see one called marker. There is a setting there to adjust the markers size. The one above is for text size.
I am not sure how every marker works but they are all probably similar.
