2010-09-01 08:08 AM
2010-09-01 11:34 PM
2010-09-02 01:08 AM
snapcrackle wrote:Yes, that has generally worked. This doesn't address the problem of not being able to set these items in the elevation marker dialog box from plan view even one at a time, let alone en mass. This is a serious, time sucking problem.
Did you try to change the >Elevation Selections Settings >Story Levels >Built in Story Marker >"text height". That's the one with the capital M joined to an up/down arrow. Works for me.
Snap
EDIT: I did this while in an elevation view.
2010-09-02 02:17 AM
2010-09-02 02:46 AM
snapcrackle wrote:I do use Favorites extensively. I only realized this problem when I opened a file in AC 14 that was started in 13 and the settings did not transfer. I begin all projects from a highly customized template, so to have to make these corrections at all is a pain. When I have to make them over and over because of a glitch is really annoying.
What about using favorites to reduce the tedium?
I've been thinking about Lazlo's recent referal to a macro recorder that can go to do repetitive work within an AC file. I'm not sure he was recommending it, just saying he used one.
Snap
