Empty fill vs air space
R Muller
Can anyone tell me the difference between "empty fill" and "airspace"?
Thanks in advance.
R Muller
AC 28 USA (20+ years on ArchiCAD)
MBP 64GB Apple M1 Max OS 15 Sequoia
TomWaltz
They are the same, they just have different names.
It's useful when you are making composites and want to have an empty fill (like studs) in a material that is next to an air space. IF they were the same fill, Archicad would remove the line between them.
Tom Waltz
SeaGeoff
Ace
Is it not also the case that airspace is ignored when calculating the volumes of components?
Regards,
Geoff Briggs
I & I Design, Seattle, USA
AC7-28, M1 Mac, OS 15.x
Graphisoft Insider's Panel, Beta Tester
Also, if a material has Empty Fill assigned in (IE) vectorial hatching it will actually have a fill, whereas Air Space has no fill whatsoever. See attached.
