Enabling Panning function using mouse scroll button....
Can't seem to pan when I click down the mouse scroll button.....
Any suggestions will be appreciated...
Using XP pro and ArchiCAD 9.
Thanks in advanced.
16 Replies 16
__archiben
Rod wrote:
I have 7 actions assigned.
who says you can't teach an old dog new tricks, eh?
~/youngben.
b e n _ f r o s t
vistasp
Mentor
Great!
Ok, so next question: How does one assign the extra buttons if there's no option in the Work Environment?
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Rod Jurich
vistasp wrote:
Great!
vistasp, I see you are with the "dark side"
You do not have any setting in the WE, it is a matter of what type of mouse driver you use.
There are a number of very good 3rd party apps available for Mac.
Have used various rodents over the years, and always return to my faithful Kensington.
Suggest you Google for type of mouse you presently use.
Maybe somebody from the "dark side" will chime in.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
vistasp
Mentor
Yep, that I am! Have been stuck with the evil empire since DOS 3.something
My mouse (it's made by M$... horrors!) allows me to configure its buttons separately for individual programs. However, I was thinking more along the lines of specific AC commands. I guess that's not possible. Yet!
= v i s t a s p =
bT Square Peg
Rod Jurich
vistasp wrote:
/.....However, I was thinking more along the lines of specific AC commands. I guess that's not possible. Yet!
Yes you can vistasp, if you look at the top and bottom button actions
in my pic, they are mapped to my shortcuts created in my WE.
I have these set differently in other apps.
Rod Jurich
The "dark side" isn't that bad
Anyways...
I talked it over with my friend, and it's just as what you guys have mentioned awhile ago....the settings have to be set using the mouse's control panel. Depending on the type of mouse one has, this process may differ, but should be able to configure it accordingly to allow for panning in ArchiCAD using the scroll 'click'.
Thanks for all the input people. The Force is strong in this Forum.
vistasp
Mentor
Rod wrote:
if you look at the top and bottom button actions in my pic, they are mapped to my shortcuts created in my WE.
Whoa! Missed that. Thanks for pointing the way, Rod. I've found this small utility called "X-mouse button control" which works on XP/Vista and allows you to send a custom keystoke sequence to specific applications.
http://www.highrez.co.uk/downloads/XMouseButtonControl.htm
Screenshot from the developer's website:
= v i s t a s p =
bT Square Peg
