2005-12-26
05:19 PM
- last edited
a week ago
Molinda Prey
2005-12-26 05:43 PM
Josephus wrote:Sadly, no. The trick/workaround is to use the magic wand on a circle. Change the segments along circle in the Magic Wand Settings to be the number of sides for the polygon (e.g., 5 for pentagon), then magic wand (space click) the circle with a line tool active.
Does AC have a tool that is similar to Autocad's "polygon" tool that creates equilateral sided polygons with user input to the number of equal sides for the polygon, ie a pentagon or octagon?
2005-12-26 06:08 PM
2005-12-27 06:22 PM
2005-12-28 01:03 AM
Erika wrote:Thank you, that works for me too.
Another way to do this is to set the 'special snap points' in the coordinate box to the number of sides of your polygon. These can then be traced with the polyline or line tool to create your polygon of choice.
2006-01-02 04:46 PM
Josephus wrote:There is an object called "ArchiGon" made by David Larrew that lets you draw equilateral polygons.Erika wrote:Thank you, that works for me too.
2006-01-09 04:59 PM
2006-01-10 04:32 AM
TomWaltz wrote:
Interestingly Archicad only seems to allow polygons up to 8 sides before it considers it to be a circle.
I guess I'll need to dig out my old drafting book and figure out the math for higher-side count shapes....
2006-01-10 08:41 AM
TomWaltz wrote:Hm?
