Error Report? why?
rob2218
I keep getting this error report ALL over the place. Different drawings, different views, different layouts.....why?
C:\Program Files\GRAPHISOFT\ArchiCAD 17\ArchiCAD.exe
Unused in temporary folder : 786778.7 MB
OpenGL
ATI Technologies Inc. AMD Radeon HD 7350
Your OpenGL driver supports all necessary extensions.
Vertical Sync: OFF
Z buffer: 24 bits
Per Pixel Lighting: ON, 4.20
Stencil buffer: 8 bits
Beginning generation of Section/Elevation:
Start time : 4/25/2014 10:29:31 AM
Polygon is degenerated.
Number of processor cores : 8
Document name : 1216_BIM Model [bimexternal.cgsarchitects.com-lba02]
Processed : 108 walls 118 objects 31 columns 93 beams
35 slabs 3 meshes 2 roofs 4 morphs
curtain wall: 110 panels 0 accessories 316 frames 4 segments 0 junctions
Start time : 4/25/2014 10:29:57 AM
End time : 4/25/2014 10:30:02 AM
Elapsed time : 5 seconds
Creating section
End time : 4/25/2014 10:30:06 AM
Elapsed time : 0 seconds
Projection : Front view
Hidden polygon removal
Sun direction : vertical 45 horizontal 45
Start time : 4/25/2014 10:30:06 AM
End time : 4/25/2014 10:30:07 AM
Elapsed time : 1 seconds
Finished generation of Section/Elevation.
End time : 4/25/2014 10:30:08 AM
Elapsed time : 37 seconds
OpenGL
Vertical Sync: OFF
Z buffer: 24 bits
Processed : 48 walls 37 objects 2 columns 13 beams
3 slabs 0 meshes 0 roofs 0 morphs
curtain wall: 7 panels 0 accessories 24 frames 0 segments 0 junctions
Start time : 4/25/2014 10:37:30 AM
End time : 4/25/2014 10:37:31 AM
Projection : Perspective
Eye position : 9.68632 24.1214 72.0755
Direction : 0.95039 -0.310835 0.0118094
Distance : 25.1345 Angle : 80
Start time : 4/25/2014 10:37:31 AM
Eye position : 40.6348 48.1249 113.733
Direction : -0.134091 -0.604204 -0.785466
Start time : 4/25/2014 10:37:34 AM
End time : 4/25/2014 10:37:34 AM
Eye position : 8.04058 37.3709 70.9939
Direction : 0.630321 -0.734684 -0.250869
Start time : 4/25/2014 10:37:50 AM
End time : 4/25/2014 10:37:50 AM
Processed : 1 walls 2 objects 0 columns 2 beams
1 slabs 0 meshes 0 roofs 0 morphs
Start time : 4/25/2014 10:38:50 AM
End time : 4/25/2014 10:38:50 AM
Eye position : 7.78382 37.3432 70.4078
Direction : 0.63726 -0.733935 -0.23503
Eye position : 2.98364 7.05713 66.9522
Direction : 0.978283 0.0955359 -0.183945
Start time : 4/25/2014 10:39:02 AM
End time : 4/25/2014 10:39:02 AM
Start time : 4/25/2014 10:39:08 AM
End time : 4/25/2014 10:39:08 AM
Eye position : 7.37392 27.7573 56.9776
Direction : 0.794034 -0.587183 0.157244
Start time : 4/25/2014 10:39:16 AM
End time : 4/25/2014 10:39:16 AM
Start time : 4/25/2014 10:39:23 AM
End time : 4/25/2014 10:39:23 AM
Start time : 4/25/2014 10:39:34 AM
End time : 4/25/2014 10:39:34 AM
Eye position : 61.6499 -0.589258 52.6617
Direction : -0.901231 0.354005 0.249927
Start time : 4/25/2014 10:39:45 AM
End time : 4/25/2014 10:39:45 AM
Processed : 56 walls 27 objects 2 columns 18 beams
26 slabs 3 meshes 0 roofs 0 morphs
Start time : 4/25/2014 10:39:48 AM
End time : 4/25/2014 10:39:48 AM
Eye position : 3.83871 -1.50444 57.3424
Direction : 0.905275 0.424793 -0.00538503
Start time : 4/25/2014 10:40:31 AM
End time : 4/25/2014 10:40:31 AM
Processed : 6 walls 1 objects 2 columns 1 beams
Start time : 4/25/2014 10:40:44 AM
End time : 4/25/2014 10:40:44 AM
Eye position : 1.25107 11.5917 61.524
Direction : 0.989852 -0.00326004 -0.142062
Start time : 4/25/2014 10:40:51 AM
End time : 4/25/2014 10:40:51 AM
Processed : 3 walls 2 objects 0 columns 4 beams
Start time : 4/25/2014 10:42:03 AM
End time : 4/25/2014 10:42:03 AM
Eye position : 8.38575 38.7227 62.0013
Direction : 0.648168 -0.75851 -0.0673821
Start time : 4/25/2014 10:47:59 AM
Processed : 76 walls 86 objects 1 columns 18 beams
27 slabs 0 meshes 0 roofs 0 morphs
Start time : 4/25/2014 10:48:00 AM
End time : 4/25/2014 10:48:01 AM
Creating section
Start time : 4/25/2014 10:48:01 AM
Elapsed time : 2 seconds
OpenGL
Vertical Sync: OFF
Z buffer: 24 bits
OpenGL
Vertical Sync: OFF
Z buffer: 24 bits
Start time : 4/25/2014 11:17:50 AM
Processed : 25 walls 36 objects 0 columns 1 beams
4 slabs 0 meshes 0 roofs 0 morphs
End time : 4/25/2014 11:17:51 AM
Creating section
Sun direction : vertical 45 horizontal 135
Start time : 4/25/2014 11:17:51 AM
OpenGL
Vertical Sync: OFF
Z buffer: 24 bits
Start time : 4/25/2014 11:36:04 AM
Processed : 21 walls 34 objects 0 columns 1 beams
16 slabs 0 meshes 0 roofs 0 morphs
End time : 4/25/2014 11:36:05 AM
Creating section
Start time : 4/25/2014 11:36:05 AM
Processed : 0 walls 2 objects 0 columns 0 beams
Start time : 4/25/2014 11:38:53 AM
End time : 4/25/2014 11:38:53 AM
Eye position : -3.3221 19.2239 61.3027
Direction : 0.975977 -0.21256 -0.0478208
Processed : 3 walls 2 objects 0 columns 1 beams
Start time : 4/25/2014 11:39:09 AM
End time : 4/25/2014 11:39:09 AM
Eye position : 41.3785 38.0171 57.4324
Direction : -0.44166 -0.893364 0.082694
Eye position : -4.81976 2.51667 75.4539
Direction : 0.898902 0.274774 -0.341284
Start time : 4/25/2014 11:39:21 AM
End time : 4/25/2014 11:39:21 AM
Processed : 54 walls 40 objects 0 columns 7 beams
27 slabs 3 meshes 0 roofs 0 morphs
Start time : 4/25/2014 11:39:34 AM
End time : 4/25/2014 11:39:36 AM
Start time : 4/25/2014 11:39:36 AM
Eye position : 34.1401 41.9653 70.7123
Direction : -0.212137 -0.938353 -0.27293
Start time : 4/25/2014 11:39:56 AM
End time : 4/25/2014 11:39:56 AM
Processed : 1 walls 1 objects 0 columns 1 beams
Start time : 4/25/2014 11:40:00 AM
End time : 4/25/2014 11:40:00 AM
Start time : 4/25/2014 11:48:16 AM
Processed : 59 walls 48 objects 1 columns 8 beams
18 slabs 0 meshes 0 roofs 0 morphs
Start time : 4/25/2014 11:48:17 AM
End time : 4/25/2014 11:48:18 AM
Creating section
Start time : 4/25/2014 11:48:18 AM
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
You realize you can call tech support, right? 🙂
Putting aside what you have for your current reporting setting (you can control what reports and detail you see)... Most of the report is just normal "yes, all is fine" noise.
But, when something is wrong, you will actually see the report window... and in your case... let's just look at the top 10:29 generation as well as the bottom for the last generation at 11:48 am today: you have degenerated polygons in section.
You need to determine which section is causing the problem... if the message came up during a publisher session it won't be oibvious...if it came up when you opened a section, it will be. Then, you need to follow the advice for this error on the forums... and use a divide and conquer technique to find which library part or morph (most likely) is causing the error... and then figure out what parameter is bad. Fix the error, and the reports will stop.
See;
http://www.archicadwiki.com/results.html?q=polygon%20is%20degenerated
rob2218
true.....I haven't called tech support in a while.
thank you forgot bout that.
See;
i>u
Edgewater, FL!
SOFTWARE VERSION:
David Maudlin
This could also be from a Slab, Roof or Mesh, but my money is on a library part (Object, Door or Window).
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
