Error Triangle
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2016-06-14
11:22 PM
2023-05-24
08:39 AM
Rubia Torres
2016-06-14
11:22 PM
>ArchiCAD 23, 7000 USA FULL
>iMac, 27-inch, 2020, Processor: 3.8 GHz 8-Core Intel Core i7, Memory: 64 GB 2667 MHz DDR4, Graphics: AMD Radeon Pro 5500 XT 8 GB
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-06-14 11:56 PM
2016-06-14
11:56 PM
Hovering on the yellow triangle indicates you have legacy option enabled.
Go to your Project Preferences to the Legacy panel, turn off the check box for the older intersection method. Which changed in ARCHICAD 17.
James Badcock
Graphisoft Senior Product Manager
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-06-15 06:10 PM
2016-06-15
06:10 PM
That fixed the problem, but now the way my complex profiles join with other elements in section is messed up. It goes back to being correct when I check the box in the Legacy options for the intersections. I am not sure why the complex profile joinery is acting this way with that button unchecked. I am also not sure how to fix this problem now.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-06-15 06:26 PM
2016-06-15
06:26 PM
When this legacy option is ON, then intersections between elements are as per AC16 and before - so no skin based intersections/clean up (i.e. no Priority Based Connections), also no skin based surfaces.
http://helpcenter.graphisoft.com/guides/archicad-19/archicad-19-int-reference-guide/elements-of-the-... #
Turning this option OFF, will consider Building Material Intersection Priority values for skins, so your model will appear differently as a result due to the Priority Based Connections.
James Badcock
