Export/ Import Favorites AC25
JR1
I exported a favorite composite as a prf file from one of my Archicad projects. When trying to import the prf file into another project, the correct name comes through but the composite composition is incorrect. For example I'll export a 2x6 wall with 1/2" sheathing on either side, and it will import with a random layer of 5/8" drywall on the exterior. Let me know if anyone has any idea as to why it the composite changes so much in the import/ export process.
Thanks!
1 REPLY 1
It’ll likely be because the attributes between the two projects do not match.
Lee Hankins
macOS Sequoia (15.1.1)
