Learn more
Export scheme issue
I'm building a new template for a new job. I made some new palette and toolbar schemes for my colleagues. When I try to export them, when I select the file path I desire the export button remains grey. Weird. Any tips?
7 Replies 7
Even if you choose a file path where you know you definitely have write access?
David Maudlin
Michael:
I am seeing the same result when trying to export a Scheme. I am able to export a Profile, so you could try that, then just Import the Scheme(s) you want.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I am not seeing any problems at all.
Can you show a screen shot of where you are getting stuck?
David Maudlin
Barry:
It occurs at the 2nd Scheme Export dialog box. Same location works for exporting the Profile (so can't be a permissions issue). Maybe its a bug on the Mac.
David
Link
Does it work without the "/"? It probably won't allow special characters - that one in particular would indicate another folder.
Link.
Morning (In Oz)
Removing any special characters has resolved the issue. I had a / in my naming convention.
Cheers guys.
David Maudlin
That was it, good catch Link.
David
