Export to DWG overlapping items
stevini
Hello Folks 🙂
I draw a multi-storeys building and I need to export it in dwg. When I visualize, for instance the second floor, and export it to dwg, the file I get shows all the elements underneath the selected floor I am exporting. So, while in Archicad, the floor plan is clean, in autocad, it shows the second floor overlapping the 3 floors below.
How can I do?
13 REPLIES 13
Files/interoperability/dwg dxf translators
Then import a new translator
Here import the xml file
Finaly use this dwg translator when you publish dwg file from the layout
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 28 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
Ok I managed to use it but the result is the same. In autocad I visualize each floor with all the elements of the floors below that I shoudn't see. For example, all the walls and stairs which are under the slab and they shoudn't be visible. Now I have to go. Tomorrow I will send you a screeshot of what I am saying. And anyway thank you very much for your support! I really appreciate
I managed to solve the problem! I had to select each element on each floor and in "Floor Plan Display" select "Home Story Only". In this way I have a dwg drawing clean and tidy exactly the same I visualize in Archicad. Thanks anyway a lot for the support!
Of course Yes !
I did not think about this.
Christophe - FRANCE
