Llian
External dwg origin
I looked through the search and not getting the answer. I also opened the translator and not finding it.
I am placing couple of external dwg plans into archicad but it doesn't have option as to whether it should be placed where I want it to be or be placed in the same orginal dwg origin. this will be a problem of placing updated external dwg plans.
I am sure archicad is smart enough to have already thought of that issue and I am missing how to do that. Please help.
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
1 Solution
You have this option only when placing a DWG/DXF as an XREF.
In the Place XREF Dialog you can check a checkbox to place to original location or define it graphically.
If you place the DWG/DXF using the Drawing Tool, then you can move that Drawing to wherever you want.
Go to post
1 Reply 1
