Llian
section elevations
I open a hole in the mesh tool ....how do i set the depth of the hole ?
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
3 Replies 3
Llian
here's my mesh tool attributes...where can i set the depth of the hole and where can i set the view depth? right now it's showing the sea level 0.00 up to grade 122.76'...
There is no such thing called "depth of the hole" .. the hole goes all the way down
in this case you have to select "add points" and then elevate the points down.
You can also use a Slab for example to define the body that should be cut out of the Mesh and do a Solid Element Operation with the Slab as Operator and the Mesh as Target.
