Extra unwanted lines in doors and windows
Hello everyone!
How can I remove the opening lines in doors and windows? Im sorry if its too obvious but I tried most options..
Thank you
Hi. This used to drive me nuts in 3D + the solution is not exactly intuitive, but simple if you know where to look.
You'll find the option to turn the lines off in 2D+3D if you open up the selection settings box. Go to 'Parameters' and then the drop-down menu under 'opening'. Tick 'override MVO for 3D opening lines' and lots of options appear. Untick 'show opening line' + it should've vanished! Same for 2D lines.
Hope that solves your problem....
Or go into the Model View Options and you can turn them all off in one go.
You may have to save a new MVO scheme or redefine your existing ones.
