Eyebrow Dormer
Red
I have been trying to think of a good way to create these (see attachment)...
Unless I over looked it, I do not see an option to turn off the window in the skylight object.[/img]
Thanks,
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
AC6 to Current
1 REPLY 1
The roof part could be done with a sloping profiled beam (assuming the curve is constant along its axis).
The crown moulding is a bit of a trick though. That's probably best done with a morph if you've got AC16. If it's really complex you might need the morph tool for the whole thing.
