2006-09-12 11:20 PM
2006-09-13 02:11 AM
2006-09-13 03:59 AM
2006-09-13 06:35 AM
2006-09-13 06:36 AM
Matthew wrote:Thank you
I believe that F1 is locked by MS as the help key in Windows. Too bad
2006-09-13 06:37 AM
Mike wrote:The biggest problem is that I cannot choose "assign" for F1 key (the "assign" button is disabled in this case). Should I do something else first?
My F1 key is set to something else. make sure you are re-defineing the short cut properly. Chose assign and overwrite the old one as you are prompted
2006-09-13 03:22 PM
adytc wrote:I'm on a MacMike wrote:The biggest problem is that I cannot choose "assign" for F1 key (the "assign" button is disabled in this case). Should I do something else first?
Thank you.
2006-09-13 07:57 PM
2006-09-13 07:57 PM
Mike wrote:Lucky you ...adytc wrote:I'm on a MacMike wrote:The biggest problem is that I cannot choose "assign" for F1 key (the "assign" button is disabled in this case). Should I do something else first?
Thank you.
2006-09-13 08:02 PM
g.h.design wrote:
Yeah, it is called a MS system key in AC10. Not the case in AC9 though. It can be changed in 9. I dunno. I don't use it in ten as I don't know a work around.
