FILL FOR CUT WALL
Llian
I never thought about this…how do I change the fill of the cut wall to say, hatch instead of the solid color in the foreground and background?
Lilian Seow
LEED AP | cSBA | CAPM | PMP
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
1 REPLY 1
Assuming it is a composite wall then you need to edit the Building Material that is used in the composite.
Edit the BM to use a hatch fill rather than a solid (or empty) fill.
You can also set the default colours for the hatch lines and background there as well.
