FLIPPING ARCS
I wonder if anyone else has experienced this problem.
On one of our workstations, we find that an arc, drawn in Archicad, will 'flip' through the x-x axis when published to Plotmaker. As a result, the arcs have to be redrawn and published a second time, when everything appears normal. However after a few days, on re-opening the drawing in Plotmaker, the arcs have all flipped again, and require to be redrawn in Archicad and republished again.
Today we found a similar thing happened when copying an arc to the next storey using 'copy and paste'. On the ground floor the arc curves from north to east - but on the first floor the arc curves from east to south.
Has anyone any idea why this should happen?
(ARCHICAD 9, on Mac workstations running OSX)
This is known bug and is corrected in last version of AC!
Have you updated your AC9 up to build# 2172?
Thanks Zohrab.
I suspect that this one machine has not been updated, as no-one else in the office suffers from it.
- K
