‎2011-07-06
02:55 PM
‎2023-05-23
06:07 PM
Rubia Torres
‎2011-07-06 05:32 PM
‎2011-07-06 05:37 PM
‎2011-07-06 07:35 PM
rob2218 wrote:You could do this with the Modular Joinery object - refer to the attached image. The rails and sashes on all sides are fully and individually adjustable for every door and window within the unit. The object should be freely available from your reseller.
how can I adjust the bottom frame height of the sidelight to match the door bottom rail???
‎2011-07-06 07:45 PM
‎2011-07-06 07:59 PM
rob2218 wrote:For some background on the object, follow the link I put in my previous post (
What is modular joinery objects anyway?
Also....how does that particular door you showed in the brick wall show up on the schedules?
‎2011-07-06 10:23 PM
‎2011-07-07 12:57 AM
‎2011-07-08 06:31 PM
‎2011-07-09 06:36 PM
rob2218 wrote:The MJO allows you to edit just about
Would that "modular joinery" object do the same trick?
