FRENCH DOOR WITH SIDELIGHTS - HOW TO GET THE SAME?
rob2218
see attached image.
I have selected a french door panel.
I have the flexibility of adjusting the side, top and bottom rails of the french door but am only limited to adjusting the "frame width" of the sidelights....how can I adjust the bottom frame height of the sidelight to match the door bottom rail??? Please don't tell me this is not built into the programming?...please.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
15 REPLIES 15
rob2218
Wow!...seems like an awesome functionality. Now...why isnt' something like this just simply "INCLUDED" in the out of the box door functionality of the software? Is it because this is a 3rd party software object and only given to UK folks???......What's the deal with this object?
Also, will AC15 have this much control over it's doors/window joinery objects? Is there a Multi-Joinery object in AC15 out of the box???
i>u
Edgewater, FL!
SOFTWARE VERSION:
That illustration barely scratches the surface - it does a lot more. Graphisoft UK, which commissioned (and own) the object, have made it available to resellers around the world to distribute to customers (for free). But communication generally seems to be a bit broken and I suspect the vast majority of users have no idea it exists.
I've been told it can't be included in the standard library because - in a nutshell - it's different, i.e. doesn't use the macros that other doors/windows do and has a different user interface. It's a classic catch-22 because it has to be different to do what it does. The object is a great showcase for what GDL is capable of, and it has been frustrating to see it held back.
Ralph Wessel BArch
Central Innovation
rob2218
yeah....so the only downside is that you have to make sure you load "another" library into your BIM database...ok. That's not too bad. it's ok. Wonder if AC15 has this type of customization with regards to it's doors/windows?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Stress Co_
Update:
D2 2Sidelight 16 door object....... Still useless
Marc Corney, Architect
Red Canoe Architecture, P. A.
rob2218
Geez....when the heck will we ever get some form of NANAWALL door for Pete's sake!!!???...
These doors are being used everywhere and to think we don't have one available in the U.S. version of Archicad?
i>u
Edgewater, FL!
SOFTWARE VERSION:
matthewjj
Try the Storefront object with a transom. You can dig into the old school parameters and there is a section called "shape" the first option listed is a toggle to turn the transom on/off. The sidelights lower rail can be edited in the parameters as well.
matt johnson
archicad since 2004
imac 27, 4.2 GHz Intel i7, 16 GB RAM, radeon 575 4 GB, macOS 10.14.6
imac, 4.0ghz i7, 16gb ram, Radeon M9 390 2GB, OS X El Capitan
