ā2022-10-28
04:09 PM
ā2023-05-09
03:10 PM
Rubia Torres
ā2022-10-29 04:55 PM
Not with the stairmaker-tool, but simply manually with other tools like slabs or morph - not much effort.
ā2022-11-03 10:48 AM
Yes you can. A bit of elbow grease and time will do. Just create a stair that fits and kind of looks the part and then manually edit each tread and rise to optimize.
ā2022-11-03 11:04 AM - edited ā2022-11-03 11:06 AM
The stair tool is enough. You can edit threads, risers and the structure also.
ā2022-11-03 12:35 PM
Doing so, you will have to pay attention not to change the measures of the line-of-going - the measures of steps and risers on the position in ths going line must not be alterd. But yes - its possible.
ā2022-11-04 09:17 AM
Thank you all for your responses!! I'm new to Archicad and Stair Tool drove me nuts at first. I managed to draw stairs with Morph Tool this time around and will add the line-of-going and measures later on when I translate it to dwg, but will try again to do it with Stair Tool too.
ā2022-11-04 09:41 AM
You have to get used to it, but it's a powerful tool. One of the advantages is the integrated floor plan display. In fact, everything you've done with the morph-tool you could have done in the stair-tool. The tool allows the use of morphs for your treads š
ā2022-11-04 12:34 PM
Because its interesting:
