File Not Found on opening ArchiCAD 10
fuzzytnth3
Hi has anyone else come across this problem?
When starting up ArchiCAD 10 if I try to use the "Select a Recent Project" list it doesn't list the names of any of the previously opened drawings and just shows an icon of the pln on the left side of the column.
If I try to open say the file at the top of the list AC10 comes up with a "file not found" error
TIA
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
6 REPLIES 6
That issue has been present since the early betas. For what it's worth, they know about it.
It only happens to files on a server. Local files will show. Not much help!
You have to browse.
James Murray
Archicad 27 • Rill Architects • macOS • OnLand.info
TomWaltz
Really? I have not seen that one before.... I guess my Mac likes me better 😉
Tom Waltz
fuzzytnth3
You have to browse.
Even fairly small sized offices have a server, so I bet this effects quite a few peeps out there.
Is it just a Mac Server issue or does it effect Windoze Servers as well?
We use a xserve with mac os x server 10.4.x with an AFP share for our projects. I have always had the file name listed in my recent files list. Even when we are NOT connected to the server opening archicad still shows the name of the files last opened on the server. Is this problem consistent with all your machines or just one?
fuzzytnth3
We only just got AC 10 today and have only installed it on two G5s so far. They both are having the same problem though.
With AC 9 we can do the same as you describe. We are running a G5 server with OSX 10.3.9 Server. But it sounds like this has been an issue for some time in beta.
I sure hope the boffins are on the case as it's going to be annoying for the folks here who are used to this working for them. If they are using a Teamshare file saved on their local hard disk it sounds like it will be ok.
kevin b
We have the exact problem as well. Very annoying.
kevin s burns, AIA
massachusetts, usa
AC25 (1413), since AC6
Windows 10
Intel Core i7 -8700 @ 3.2 GHz~ 16 GB ram
