Fill Bug!
Hi Gentlemen
Have you experienced this Bug? (Video attached)
http://www.screencast.com/t/pYl8kGc7jgn
I'm using AC12 2675 Int Full.
Regards
Nando M
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
3 Replies 3
Dwight
Tested it and no insect. Excited States version.
Dwight Atkinson
It works fine for me! What are the critical dimensions for this to happen? What shape is the fill? I notice from the video that it only occurred when the thin segment was under a certain width. Does it happen if you use a slab the same shape?
Another point (probably unrelated) was why the preview outline uses a dot-dash linetype? Mine appears solid. Is that normal?
NandoMogollon wrote:
Hi Gentlemen
Regards
Nando M
Try to recreate the nodes at the two ends of the problematic edge.
OR maybe you can cut off the right end of the fill with a vertical cut line and it will appear.
To me it seems like the Fill polygon is degenerated in some way or its data structure is.
