Fill Bug!
Hi Gentlemen
Have you experienced this Bug? (Video attached)
http://www.screencast.com/t/pYl8kGc7jgn
I'm using AC12 2675 Int Full.
Regards
Nando M
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Dwight
Tested it and no insect. Excited States version.
Dwight Atkinson
It works fine for me! What are the critical dimensions for this to happen? What shape is the fill? I notice from the video that it only occurred when the thin segment was under a certain width. Does it happen if you use a slab the same shape?
Another point (probably unrelated) was why the preview outline uses a dot-dash linetype? Mine appears solid. Is that normal?
NandoMogollon wrote:
Hi Gentlemen
Regards
Nando M
Try to recreate the nodes at the two ends of the problematic edge.
OR maybe you can cut off the right end of the fill with a vertical cut line and it will appear.
To me it seems like the Fill polygon is degenerated in some way or its data structure is.
