You should read about Graphic Overrides. If you came from Revit, they are similar to what Revit's View Filters do.
You can create Graphic Override Rules which specify Criteria and Override Style. Elements meeting the Criteria will be overridden by the Override Style that can override Line Type, Pen, Fill Type, Fill Pens, and Surface.
Then you can create Graphic Override Combinations. Each Graphic Override Combination can be composed of any number of Graphic Override Rules.
Here is a Graphic Override Rule, which will override the Fill Type of all Walls, Slabs, and Roofs with a white background, and the Pen of the contours of these structures with a black Pen, with the resulting Section of a Wall-Slab intersection:
