Fill Problems In Sketch Rendering
Vectorial Hatching is having random problems. See the Image. I can't seem to find a solution. I have changed all the settings and rendered on my second computer with different graphics card. Identical errors so I am thinking it is an archicad issue. Anyone seen this? Work-arounds?
Thanks
(notice the roof tile hatch seems to drop to lower part of roof object. If I change viewpoint the fills will change and sometimes be flawless. Mostly though, there are errors.)
3 Replies 3
I get similiar errors. But since it is "sketch" render it doesnt bother me.
If i was you i would use photoshop and clone the area below.
Jefferson
G.H.
A while back I posted this :
http://archicad-talk.graphisoft.com/viewtopic.php?t=2744
after experiencing nondesirable results. While not exactly the same as yours I suspect they could, and are likely related. Note I am still using 8.1 but I believe the sketch engine other than rendering speed is the same basic product. Hope that helps or at least leads to better understanding of how to drive this vaulable tool within ArchiCAD. Actually I tend to think of it like an old truck, you guide it more than drive it. Please do share any further insights you come up with.
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
try rebuilding the 3d view (view>rebuild) immediately before you render it
it's not a graphics card issue. rendering is done by the cpu
bill
