We value your input!
Fill scale in 1/8" drawing
I am printing a set at 1/8" scale though when I scale it down the fills for concrete footing and grade do not change? Is there a way to scale them correctly?
If you look at your fill options (Options - Element Attributes - Fill Types in v.11) there is a check box for scale independent or scale with plan. I would guess that the same/similiar in v.10
found it, thanks
